APC Rack PDU 2G Metered ZeroU 22.0kW
Quicklinx: B8YVWS00 Mfr#: AP8886
24 in stock
£1,300.38 ex VAT
£1,560.45 inc VAT
APC Metered Rack Power Distribution Units (PDUs) provide active metering to enable energy optimization and circuit protection. User-defined alarm thresholds mitigate risk with real-time local and remote alerts to warn of potential circuit overloads. Metered Rack PDUs provide power utilization data to allow Data Center Managers to make informed decisions on load balancing and right sizing IT environments to lower total cost of ownership. Users can access and configure Metered Rack PDUs through secure Web, SNMP, or Telnet Interfaces which are complimented by APC Centralized Management platforms using StruxureWare Data Center Expert, Operations, Capacity, and Energy Efficiency. New AP8000 series Metered Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and ultra-low profile circuit breakers.
  • Remote Management Capabilities
    Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements.
  • Local Current Monitoring Display
    The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
  • Alarm Thresholds
    Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems.
  • Load indicator LED
    Indicates overload and warning conditions based on the user-defined alarm thresholds. Alerts users of potential overloaded circuits.
  • Integrates with StruxureWare Data Center Expert
    An IT-ready, scalable access monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network
  • Flash Upgradeable
    Quickly and easily upgrade firmware via network download for future product enhancements. Eliminates the need to replace products already installed in the field when new features are released.
APC Metered Rack PDU - power distribution unit
Power distribution unit - rack-mountable
Rack Size
0U
8.72 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
230 V
Input Connectors
1 x power IEC 60309 32A
Output connectors
30 x power IEC 60320 C13 , 12 x power IEC 60320 C19
Ethernet, RS-232, USB
Remote Management Protocol
SNMP, Telnet, HTTP, SSH
5.6 cm x 5.1 cm x 182.9 cm
P/N: AR3100, SMC1000I-2UC, SMC1500I-2UC, SMC1500IC, SMX3000RMHV2UNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT5KRMXLW-HW, SUA5000RMI5U, SURT1000XLI, SURT2000XLI, SYA8K8RMI
Height (Rack Units)
0U
Input Voltage
AC 400 V
Input Wiring
3-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
230 V
Max Electric Current
32 A
Circuit Protection
Circuit breaker
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x serial , 1 x USB
Power cable 1.8 m , Serial cable - external
Rack Mounting Kit
Included
LCD display, current meter, over current protection, overload protection
EN 61000-3-2, ICES-003, VDE, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, RoHS, FCC Part 15 A, REACH
50 °C
5 - 95%
5.6 cm
5.1 cm
182.9 cm
8.72 kg
Shipping Width
17 cm
Shipping Depth
12 cm
Shipping Height
205 cm
Shipping Weight
11.6 kg
Brand: APC
Price Range Ex VAT: 1000 - 1500
