Your basket is empty
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19
Quicklinx: 86BDWS00 Mfr#: AP8881
Type: PDU
Power Rating: 11kW
Hurry, only 3 left in stock!
£632.67 ex VAT
£759.20 inc VAT
APC Metered Rack Power Distribution Units (PDUs) provide active metering to enable energy optimization and circuit protection. User-defined alarm thresholds mitigate risk with real-time local and remote alerts to warn of potential circuit overloads. Metered Rack PDUs provide power utilization data to allow data center managers to make informed decisions on load balancing and right sizing IT environments to lower total cost of ownership. Metered Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and ultra low profile circuit breakers. Users can access and configure Metered Rack PDUs through secure web, SNMP, or telnet interfaces which are complimented by APC centralized management platforms using InfraStruxure central, operations, capacity, and energy efficiency.
APC Metered Rack PDU - power distribution strip - 11 kW
Power distribution strip - rack-mountable
Rack Size
0U
6.4 kg
Input Voltage
AC 400 V
Output Voltage
AC 230 V
Power Capacity
11 kW
Input Connectors
Power IEC 60309 16A, power IEC 60309 20A
Output connectors
36 x power IEC 60320 C13 , 6 x power IEC 60320 C19
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.4 cm x 179 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC
Height (Rack Units)
0U
Input Voltage
AC 400 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
11 kW
Circuit Protection
Circuit breaker
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (Ethernet) - RJ-45 , 1 x management (RS-232)
Power cable - 1.8 m , Serial cable - external
Rack Mounting Kit
Included
LCD display
VDE, IEC 60950, CSA 22.2 No. 60950, RoHS, UL 60950-1, REACH
5 °C
45 °C
5 - 95%
5.6 cm
4.4 cm
179 cm
6.4 kg
Shipping Width
16.2 cm
Shipping Depth
10.7 cm
Shipping Height
200 cm
Shipping Weight
8 kg
Type: PDU
Power Rating: 11kW
Brand: APC
Price Range Ex VAT: 500 - 750
