APC Rack Automatic Transfer Switch
Quicklinx: 7Z9MWS00 Mfr#: AP7721
Type: Transfer Switch
Power Rating: [N/A]
£518.70 ex VAT
£622.44 inc VAT
The American Power Conversion (APC) Rack Automatic Transfer Switch (ATS) provides reliable, redundant power to single-corded equipment. The Rack ATS has dual input power cords supplying power to the connected load. If the primary source becomes unavailable, the Rack ATS will seamlessly source power from the secondary source without interrupting critical loads. Networked units have built-in network connectivity, which allows for remote management via Web, SNMP, or Telnet interfaces.
  • Local Current Monitoring Display
    The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip. (Available on designated SKUs only)
APC Rack Automatic Transfer Switch - redundant switch
Redundant switch - rack-mountable
Rack Size
1U
3.9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Input Connectors
2 x power IEC 60320 C14
Output connectors
12 x power IEC 60320 C13
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
43.2 cm x 22.9 cm x 4.4 cm
P/N: SC450RMI1U-3XW, SC450RMI1U-5XW, SMX3000RMHV2UNC, SUA1000RMI2U(P), SUA2200RMXLI3U-3XW, SUA2200RMXLI3U-5XW, SUA3000R2ICH, SUA3000RMI2U-AN, SUA3000RMXLI3U-5XW, SUA3000RMXLI3U-TU, SUA3000XLI-3XW, SUA3000XLI-5XW, SYA12K16I-3AVL, SYA12K16I-3HAVL, SYA12K16I-5AVL, SYA12K16I-5HAVL, SYH4K6RMI-5HAVL
Height (Rack Units)
1U
Input Voltage
AC 230 V
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
10 A
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (RS-232) - RJ-11 , 1 x management (Ethernet) - RJ-45
Serial cable - external
Rack Mounting Kit
Included
EN55022 Class A, FCC Part 15 A
-5 °C
45 °C
5 - 95%
43.2 cm
22.9 cm
4.4 cm
3.9 kg
Shipping Width
60 cm
Shipping Depth
34.9 cm
Shipping Height
11.4 cm
Shipping Weight
5.7 kg
P/N: SC450RMI1U, SC450RMI1U-3XW, SC450RMI1U-5XW, SMX3000RMHV2UNC, SU5000I, SU5000I-1EW, SU5000I-2EW, SU5000I-3AVL, SU5000I-3EW, SU5000I-3HAVL, SU5000I-3XW, SU5000I-5AVL, SU5000I-5HAVL, SU5000I-5XW, SU5000I-GLD, SU5000INET, SU5000I-SLV, SUA1000RMI2U, SUA1000RMI2U(P), SUA1000RMI2U-1EW, SUA1000RMI2U-2EW, SUA1000RMI2U-3EW, SUA1000RMI2U-3XW, SUA1000RMI2U-5XW, SUA1000RMI2U-BRZ, SUA1000RMI2U-GLD, SUA1000RMI2U-SLV, SUA1500I, SUA1500I-1EW, SUA1500I-2EW, SUA1500I-3EW, SUA1500I-3XW, SUA1500I-5XW, SUA1500I-BRZ, SUA1500I-GLD, SUA1500I-OPY, SUA1500I-SLV, SUA2200RMXLI3U, SUA2200RMXLI3U-3XW, SUA2200RMXLI3U-5XW, SUA3000I, SUA3000I-3XW, SUA3000I-5XW, SUA3000R2ICH, SUA3000RMI2U, SUA3000RMI2U/P, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-3XW, SUA3000RMI2U-5XW, SUA3000RMI2U-AN, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SUA3000RMXLI3U, SUA3000RMXLI3U-3XW, SUA3000RMXLI3U-5XW, SUA3000RMXLI3U-TU, SUA3000XLI, SUA3000XLI-3XW, SUA3000XLI-5XW, SUA750I, SUA750I-3XW, SUA750I-5XW, SUA750IX38, SUM1500RMXLI2U, SUM1500RMXLI2U-3XW, SUM1500RMXLI2U-5XW, SYA12K16I, SYA12K16I-3AVL, SYA12K16I-3HAVL, SYA12K16I-3XW, SYA12K16I-5AVL, SYA12K16I-5HAVL, SYA12K16I-5XW, SYA12K16I-TU, SYH4K6RMI, SYH4K6RMI-3AVL, SYH4K6RMI-3HAVL, SYH4K6RMI-3XW, SYH4K6RMI-5AVL, SYH4K6RMI-5HAVL, SYH4K6RMI-5XW, SYH4K6RMI-TUP
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: 500 - 750
