The Back-UPS Pro provides abundant battery backup power, so you can work through medium and extended length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. And it features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS Pro also includes unique "green" features, like power-saving outlets that automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS Pro's standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
Efficiency
UPS products considered must achieve operational efficiency in the top 25 percent of the market, thus allowing customers to realize lower electrical operating costs and a smaller carbon footprint. -
Performance tested
All UPS products are subject to the EPA's Energy Star test procedure. -
Easy-to-use auto shutdown software with power and energy management features
PowerChute Personal Edition software provides safe system shutdown in the event of an extended power outage and prevents potential data corruption. Designed for exceptional usability, it provides first-time users with optimal protection based on APC industry-leading power management expertise. Users also have the option to tailor PowerChute settings for their individual circumstances. Energy cost and CO2 information provides a greater understanding of the energy consumed by protected equipment and energy plans enable cost savings.
- APC Back-UPS Pro 1500 - UPS - 865 Watt - 1500 VA
- UPS - external
- 13.4 kg
- Input Voltage
- AC 120 V
- Output Voltage
- AC 120 V
- Power Capacity
- 865 Watt / 1500 VA
- Input Connectors
- Power NEMA 5-15
- Output connectors
- 5 x power NEMA 5-15 (surge) , 5 x power NEMA 5-15 (UPS and surge)
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 1
- Run Time (Up To)
- 3 min at full load
- 11.2 cm x 38.1 cm x 30.2 cm
- 3-year warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Input Voltage
- AC 120 V
- Input Voltage Range
- AC 88 - 139 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power NEMA 5-15
- Power Output Connectors Details
- Output Voltage
- AC 120 V 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network - RJ-45 , Cable TV/satellite/antenna
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 355 Joules
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 8 hours
- Cables Included
- Power cable - integrated - 1.8 m , USB cable - external
- Equipment Protection Value
- 150000 US Dollars
- Audible alarm, LCD display
- TUV, NOM, UL 1449, FCC Part 15 B, FCC Part 68, RoHS, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 11.2 cm
- 38.1 cm
- 30.2 cm
- 13.4 kg
- Shipping Width
- 22.9 cm
- Shipping Depth
- 48.3 cm
- Shipping Height
- 38.1 cm
- Shipping Weight
- 13.8 kg
