APC Power Saving Back-UPS RS 1500 US - USA version NOT UK
Quicklinx: CWVFWS00 Mfr#: BR1500G
The Back-UPS Pro provides abundant battery backup power, so you can work through medium and extended length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. And it features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS Pro also includes unique "green" features, like power-saving outlets that automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS Pro's standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
  • Efficiency
    UPS products considered must achieve operational efficiency in the top 25 percent of the market, thus allowing customers to realize lower electrical operating costs and a smaller carbon footprint.
  • Performance tested
    All UPS products are subject to the EPA's Energy Star test procedure.
  • Easy-to-use auto shutdown software with power and energy management features
    PowerChute Personal Edition software provides safe system shutdown in the event of an extended power outage and prevents potential data corruption. Designed for exceptional usability, it provides first-time users with optimal protection based on APC industry-leading power management expertise. Users also have the option to tailor PowerChute settings for their individual circumstances. Energy cost and CO2 information provides a greater understanding of the energy consumed by protected equipment and energy plans enable cost savings.
APC Back-UPS Pro 1500 - UPS - 865 Watt - 1500 VA
UPS - external
13.4 kg
Input Voltage
AC 120 V
Output Voltage
AC 120 V
Power Capacity
865 Watt / 1500 VA
Input Connectors
Power NEMA 5-15
Output connectors
5 x power NEMA 5-15 (surge) , 5 x power NEMA 5-15 (UPS and surge)
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
3 min at full load
11.2 cm x 38.1 cm x 30.2 cm
3-year warranty
UPS - external
Battery Enclosure Type
Plug-in module
Input Voltage
AC 120 V
Input Voltage Range
AC 88 - 139 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Power NEMA 5-15
Output Voltage
AC 120 V 50/60 Hz
Power Capacity
865 Watt / 1500 VA
Dataline Surge Protection
Network - RJ-45 , Cable TV/satellite/antenna
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
355 Joules
Quantity
1
Lead Acid
Run Time (Up To)
3 min at full load
Recharge Time
8 hours
Power cable - integrated - 1.8 m , USB cable - external
Equipment Protection Value
150000 US Dollars
Audible alarm, LCD display
TUV, NOM, UL 1449, FCC Part 15 B, FCC Part 68, RoHS, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years
0 - 95%
Sound Emission
45 dBA
11.2 cm
38.1 cm
30.2 cm
13.4 kg
Shipping Width
22.9 cm
Shipping Depth
48.3 cm
Shipping Height
38.1 cm
Shipping Weight
13.8 kg
