APC Power-Saving Back-UPS Pro 550
Quicklinx: 7C0BWS00 Mfr#: BR550GI
  • Power-saving outlets
  • Disconnected battery notification
  • Boost and trim Automatic Voltage Regulation (AVR)
  • LCD graphics display
Includes: CD with software, Cord management straps, Documentation CD, USB cable, Warranty card
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR)
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines
    Warns when a battery is not available to provide backup power
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
    Automatically cuts power to idle equipment to conserve electricity
  • Automatic Voltage Regulation (AVR)
    Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment
APC Back-UPS RS LCD 550 Master Control - UPS - 330 Watt - 550 VA
UPS - external
6.5 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
330 Watt / 550 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
3 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
Battery Form Factor
Internal
Batteries Qty
1
USB
9.1 cm x 31 cm x 19.2 cm
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 176 - 282 V
Frequency Provided
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
330 Watt / 550 VA
Dataline Surge Protection
Network - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
355 Joules
Circuit Protection
Circuit breaker
Quantity
1
Recharge Time
12 hours
Remote Management Interface
USB
Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
TUV GS, C-Tick, GOST, RoHS, A-Tick
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
40 dBA
9.1 cm
31 cm
19.2 cm
6.5 kg
Shipping Width
13.8 cm
Shipping Depth
44.2 cm
Shipping Height
25.2 cm
Shipping Weight
7.7 kg
