APC Power Saving Back-UPS Pro 1200
Quicklinx: 7C0GWS00 Mfr#: BR1200GI
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment.
Cold-start capable provides temporary battery power when the utility power is out. Hot-swappable batteries ensure clean, uninterrupted power to protected equipment while batteries are being replaced. Dataline surge protection provides protection of connected equipment from power surges on the data lines.
Includes: CD with software, Qty 2 - Detachable 2.0 m IEC power cords, Telephone Cable, USB cable, User Manual, Warranty card
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Green mode
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR)
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Serial connectivity
    Provides management of the UPS via a serial port
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power
  • Transformer-block spaced outlets
    Protect equipment with input transformer blocks without blocking access to other receptacles
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Adjustable voltage-transfer points
    Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications
  • Power-saving outlets
    Automatically cuts power to idle equipment to conserve electricity
  • Telephone dataline surge protection
    Provides protection of connected equipment from power surges traveling on telephone lines
APC Back-UPS Pro 1200 - UPS - 720 Watt - 1200 VA
UPS - external
11.6 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
720 Watt / 1200 VA
Input Connectors
Power IEC 60320 C14
Output connectors
5 x power IEC 60320 C13 (UPS and surge) , 5 x power IEC 60320 C13 (surge)
Lead Acid
Run Time (Up To)
7.6 min at full load
USB
11.2 cm x 38.2 cm x 30.2 cm
2-year warranty (European Union - 3 years)
UPS - external
Input Voltage
AC 230 V
Input Voltage Range
AC 186 - 284 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
720 Watt / 1200 VA
Dataline Surge Protection
Network - RJ-45 , Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
445 Joules
Lead Acid
Run Time (Up To)
7.6 min at full load , 19.9 min at half load
Recharge Time
8 hours
Remote Management Interface
USB
1 x management (USB)
USB cable - external
Audible alarm, LCD display
TUV, GOST, GS, RoHS, A-Tick
Limited warranty - 2 years , European Union: limited warranty - 3 years
0 - 95%
Sound Emission
45 dBA
11.2 cm
38.2 cm
30.2 cm
11.6 kg
Shipping Width
23.8 cm
Shipping Depth
48.8 cm
Shipping Height
38.7 cm
Shipping Weight
13.2 kg
7C0G APC Service Pack 1 Year Warranty Extension In Stock £42.84
7C0G APC Service Pack 3 Year Warranty Extension In Stock £97.06
