This PoE Injector allows a PoE enabled NetBotz appliance to be used with a non-PoE Ethernet switch.
- NetBotz - PoE injector
- PoE injector - external
- 6 cm x 10.2 cm x 3.2 cm
- 2-year warranty
- Designed For
- Room Monitor 355, 455
- UL, GOST, cUL, GS, ICES-003, NOM, VCCI Class A ITE, EMC, IRAM, FCC Part 15 A, PSE Mark, C-Tick Class A
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 6 cm
- 10.2 cm
- 3.2 cm
- Shipping Width
- 24.8 cm
- Shipping Depth
- 18.1 cm
- Shipping Height
- 6.2 cm
- Shipping Weight
- 0.8 kg
- Designed For
- NetBotz Room Monitor 355, 455
