APC Notebook Surge Protector for AC
Clearance!
Clearance
Price Drop
Quicklinx: B8Z1WS00 Mfr#: PNOTEPROC6-EC
Power Output Connectors: 1
£25.67 ex VAT
£30.80 inc VAT
Protecting just the AC line for a notebook computer is not enough. Lightning or other damaging surges can enter and destroy your equipment through the phone line as well. The SurgeArrest Notebook Protector protects both paths - and guarantees it!
  • Lightning and Surge Protection
    To prevent damage to your equipment from electric power surges and spikes
  • Protection Working Indicator
    SurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge
APC SurgeArrest Notebook Pro - surge protector
Surge protector - external
0.1 kg
Middle East, Africa, Europe
Input Voltage
AC 230 V
Input Connectors
1 x power IEC 60320 C6
Output connectors
1 x power IEC 60320 C5
Silver
3.2 cm x 11 cm x 2.8 cm
Silver
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
Max Electric Current
4 A
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11 - 1 input line / 2 output lines
Surge Suppression
Surge Response Time
1 ns
Surge Energy Rating
600 Joules
Clamping Level
330 V
Phone cable - external - 1.8 m , Network cable 30 cm
CSA, UL, GS, NOM, VDE, FCC Part 68
Limited warranty - lifetime
0 - 95%
3.2 cm
11 cm
2.8 cm
0.1 kg
Brand: APC
Price Range Ex VAT: 0 - 50
