APC Network Management Card With 2 Environment Monitor
Quicklinx: 62NFWS00 Mfr#: AP9631
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet
Form Factor: Plug-in module
Compatibility: PC
Type: Remote management adapter
13 in stock
£402.14 ex VAT
£482.56 inc VAT
APC UPS network management card allows for secure monitoring and control of an individual APC UPS via web browser, command line interface, or SNMP. Embedded technology provides exceptional reliability with notification features that inform you of problems as they occur.
  • BACnet/IP Support
    Supports reporting UPS information to Building Management Systems or other third party management systems via BACnet/IP (BTL certified) (Single Phase Smart-UPS and Symmetra only).
  • Command line interface
    Offers simultaneous remote management access through Telnet and SSH
  • Compatible with SmartSlot enabled UPSs
    Compatible with all SmartSlot UPSs
  • Device Encryption
    Securely connect via HTTPS/SSL, SSH (up to 2048-bit encryption), SNMPv3
  • Expandable Input and Output Ports
    Supports the Temperature Sensor, Temperature and Humidity Sensor and Dry Contact I/O Accessory
  • IPv6 Support
    Capable of operating on a network using IPv6 protocol
  • Modbus TCP Support
    Supports reporting UPS information to Building Management Systems or other third party management systems via Modbus TCP.
  • Multiple language support
    Web browser interface available in English, French, Russian, Chinese, Japanese, Korean, German, Italian, Spanish, Portuguese
  • Multiple user access
    Supports simultaneous web browser access for up to 8 users and network command line interface access for up to 3 users
  • Smart Battery Management Support
    Detailed battery information including battery cartridge parameters provides early-warning fault analysis to simplify management of the entire battery system (SRT Smart-UPS only).
  • Standard UPS RFC 1628 MIB Compatible
    Make UPS information available to your preferred network, server or enterprise management system by forwarding SNMP traps (events) using RFC 1628 MIB.
  • UPS Firmware Update
    User friendly mechanism to remotely and seamlessly update UPS firmware via the web browser interface (SMX, SMT and SRT Smart-UPS only).
APC Network Management Card 2 with Environmental Monitoring - remote management adapter
Plug-in module
12.1 cm x 11.4 cm x 3.8 cm
90 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Network / Transport Protocol
FTP
P/N: SCL500RM1UC, SCL500RM1UNC, SMT1000JOS6, SMTL1000RM2UC, SMTL1000RMI2UC, SMTL750RMI2UC, SMX2KR2UNCX145, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1000XLI, SRT1000XLJ, SRT10KXLTW, SRT1500RMXLI-NC, SRT1500XLI, SRT1500XLJ, SRT2200XLI-KR, SRT2400XLJ, SRT3000XLA-TW, SRT3000XLTW, SRT5KRMXLW-TW, SRT6KXLTW
Plug-in module
Wired
Cabling Type
FTP
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTPS, SSH, CLI, SCP
2048-bit encryption, E-mail alert, IPv6 support, firmware upgradable, RADIUS support, temperature sensor
X network - Ethernet 10Base-T/100Base-TX
Compatible Slots
1 x SmartSlot
Temperature sensor
Encryption Algorithm
SSL
C-Tick, GOST, ICES-003, EN55024, RoHS, FCC Part 15 A, REACH, AS/NZS 3548 Class A, VCCI Class A, EN 55022 Class A
Software Included
Drivers & Utilities
12.1 cm
11.4 cm
3.8 cm
90 g
Shipping Width
23.5 cm
Shipping Depth
15.9 cm
Shipping Height
5.1 cm
Shipping Weight
340 g
Limited warranty - replace or repair - 2 years
45 °C
0 - 95%
P/N: G3H10K3IM6X710, G3H10K3IM9X710, GVX1000K1000GS, GVX1000K1000HS, GVX1000K1250GS, GVX1000K1250HS, GVX1000K1500GS, GVX1000K1500HS, GVX1000K750GS, GVX1000K750HS, GVX1250K1000GS, GVX1250K1000HS, GVX1250K1250GS, GVX1250K1250HS, GVX1250K1500GS, GVX1250K1500HS, GVX1500K1250GS, GVX1500K1250HS, GVX1500K1500GS, GVX1500K1500HS, GVX1750K1500GS, GVX1750K1500HS, GVX500K1000GS, GVX500K1000HS, GVX500K1250GS, GVX500K1250HS, GVX500K1500GS, GVX500K1500HS, GVX500K500GS, GVX500K500HS, GVX500K750GS, GVX500K750HS, GVX625K1000GS, GVX625K1000HS, GVX625K625GS, GVX625K625HS, GVX750K1000GS, GVX750K1000HS, GVX750K1250GS, GVX750K1250HS, GVX750K1500GS, GVX750K1500HS, GVX750K500GS, GVX750K500HS, GVX750K750HS, SCL500RM1UC, SCL500RM1UNC, SMT1000I-AR, SMT1000IC, SMT1000JOS6, SMT1000R2I-AR, SMT1000RMI2UC, SMT1500I-AR, SMT1500IC, SMT1500NC, SMT1500R2I-AR, SMT1500RM2UNC, SMT1500RMI2UC, SMT2200C, SMT2200I2U-BR, SMT2200I-AR, SMT2200IC, SMT2200R2I-AR, SMT2200RM2UC, SMT2200RM2UNC, SMT2200RMI2UC, SMT30002U-BR, SMT3000C, SMT3000I2U-BR, SMT3000I-AR, SMT3000IC, SMT3000R2I-AR, SMT3000RM2UC, SMT3000RM2UNC, SMT3000RMI2UC, SMT750IC, SMT750JOS6, SMT750RMI2UC, SMTL1000RM2UC, SMTL1000RMI2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1000US, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200RMLVUS, SMX2KR2UNCX145, SMX2KRMLVNCUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750US, SRC1KI, SRC2KI, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1000XLI, SRT1000XLJ, SRT10KXLTUS, SRT10KXLTW, SRT10RMXLIX806, SRT1500RMXLA-NC, SRT1500RMXLI, SRT1500RMXLI-NC, SRT1500XLI, SRT1500XLJ, SRT2200RMXLAUS, SRT2200XLI-KR, SRT2400XLJ, SRT3000XLA-TW, SRT3000XLAUS, SRT3000XLTW, SRT5KRMXLTUS, SRT5KRMXLW-TW, SRT5KXLJ, SRT5KXLTUS, SRT6KXLTUS, SRT6KXLTW, SRT8KXLTUS, SRTL1000RMXLI, SRTL1000RMXLI-NC, SRTL1500RMXLI, SRTL1500RMXLI-NC, SRTL2200RMXLI, SRTL2200RMXLI-NC, SRTL3000RMXLI, SRTL3000RMXLI-NC, SUA3000I-IN, SURT20KUXI-IN, SUVTJP20KF2B4S, SY30K40E
Resources
The following resources are available for the APC Network Management Card With 2 Environment Monitor
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Brand: APC
Price Range Ex VAT: 300 - 500
