APC NetShelter SX 42U 750mm Wide x 1200mm Deep Networking Enclos
Quicklinx: 86D5WS00 Mfr#: AR3340
Depth (mm): 120cm
Type: Floor standing
U Height: 42U
Width (mm): 75cm
£1,978.73 ex VAT
£2,374.47 inc VAT
The APC NetShelter is a multi-functional rack enclosure influenced by customer feedback from around the world. These enclosures are designed to meet current IT market trends and applications ranging from high density computing and networking to broadcast and audio-video. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter rack enclosure provides a reliable rack-mounting environment for mission-critical equipment.
NetShelter SX networking enclosure expands APC's superior IT enclosure line with improved support for high density networking applications. Integrated high density cable managers and improved cable access roof provide support for large cable bundles.
  • Improved cable access
    Maintain and organize large cable bundles for improved efficiency with open vertical mounting rails and large cable openings in roof
  • Integrated high density cable management
    Decrease installation time while supporting the cabling needs of large networking switches
  • Cable protection and pass-through
    Smooth plastic fingers provide proper bend radius
  • High density cable management
    The vertical mounting rails are opened up for increased cable access and the roof design has large open areas for cable entry/exit from the enclosure
  • Optimized enclosure design for side-to-side airflow
    Airflow management panels, left vertical mounting rail, and side airflow duct kit ensure proper side-to-side airflow to the networking switches from the cold aisle and provide isolation of hot air preventing it from re-entering the cold aisle. Additionally, the front left vertical mounting rail acts as an air block for exhaust air from networking switches
APC NetShelter SX Enclosure with Sides rack - 42U
Rack
Height (Rack Units)
42U
75 cm x 120 cm x 199 cm
161 kg
5-year warranty
Rack
Height (Rack Units)
42U
75 cm
120 cm
199 cm
161 kg
EIA-310-E, RoHS, UL 60950-1, REACH
Limited warranty - 5 years
Depth (mm): 120cm
U Height: 42U
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: 1500+
