APC NetShelter SX 42U 750mm Wide x 1070mm Deep Networking Enclos
Quicklinx: 86CRWS00 Mfr#: AR3140
Depth (mm): 107cm
Type: Floor standing
U Height: 42U
Width (mm): 75cm
Hurry, only 2 left in stock!
£1,803.64 ex VAT
£2,164.36 inc VAT
NetShelter SX networking enclosure expands APC's superior IT enclosure line with improved support for high density networking applications. Integrated high density cable managers and improved cable access roof provide support for large cable bundles. When combined with the side airflow duct kit, the networking enclosure ensures complete isolation of cold intake and hot exhaust air for large switches and SAN directors.
  • Improved cable access
    Maintain and organize large cable bundles for improved efficiency with open vertical mounting rails and large cable openings in roof
  • Integrated high density cable management
    Decrease installation time while supporting the cabling needs of large networking switches
  • Cable protection and pass-through
    Smooth plastic fingers provide proper bend radius
  • High density cable management
    The vertical mounting rails are opened up for increased cable access and the roof design has large open areas for cable entry/exit from the enclosure
  • Optimized enclosure design for side-to-side airflow
    Airflow management panels, left vertical mounting rail, and side airflow duct kit ensure proper side-to-side airflow to the networking switches from the cold aisle and provide isolation of hot air preventing it from re-entering the cold aisle. Additionally, the front left vertical mounting rail acts as an air block for exhaust air from networking switches
APC NetShelter SX Networking Enclosure with Sides rack - 42U
Rack
Height (Rack Units)
42U
75 cm x 107 cm x 199 cm
156 kg
5-year warranty
P/N: SUA1000RMI2U, SUA2200RMXLI3U, SUA5000RMI5U
Rack
Height (Rack Units)
42U
75 cm
107 cm
199 cm
156 kg
Weight Limit
1363 kg
Mounting Kit
Included
EIA-310-E, RoHS, UL 60950-1
Limited warranty - 5 years
Depth (mm): 107cm
U Height: 42U
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: 1500+
