APC NetShelter CX Mini Rack with Power Distribution Unit 12U
Quicklinx: C3C1WS00 Mfr#: AR4000MV
Depth (mm): 93cm
Width (mm): 69cm
£1,411.54 ex VAT
£1,693.84 inc VAT
Netshelter CX mini is specifically designed to house a complete small-office IT installation comprised of one or two servers, network hardware and peripheral devices. It combines extreme noise reduction and moderate thermal capacity with exceptional reliability and an all-inclusive, Plug-and-Play specification. The resulting EIA rack is 600 mm/23.6" deep.
  • Integrated heat removal
    High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment
  • Integrated power strip
    Provided with a power strip which has 3 available IEC receptacles, 3 NEMA equipment power cords, 1 NEMA input cord and 1 Schuko input cord
  • Removable lockable rear panel
    Provides customers with easy accessibility to equipment and allows equipment to be installed without powering off
  • Dedicated rear cable channel
    The cable port has a capacity of up to 30 cables and is situated perfectly for ground or under-floor cabling
APC NetShelter CX Mini rack - 12U
Rack
Rack Type
Cabinet
Built-in Devices
Power distribution unit
Package Content
2 fans, brush strip, 4 casters, front door, rear door, keys, 3 outlet power distribution strip, 3 power cables
Grey, oak
Height (Rack Units)
12U
69 cm x 93 cm x 70 cm
75 kg
Soundproof enclosure, lockable front door, lockable rear door
Rack
Rack Type
Cabinet
Built-in Devices
Package Content
Height (Rack Units)
12U
69 cm
93 cm
70 cm
75 kg
Grey, oak
Weight Limit
85 kg
RoHS
Depth (mm): 93cm
Width (mm): 69cm
Brand: APC
Price Range Ex VAT: 1000 - 1500
