Netshelter CX mini is specifically designed to house a complete small-office IT installation comprised of one or two servers, network hardware and peripheral devices. It combines extreme noise reduction and moderate thermal capacity with exceptional reliability and an all-inclusive, Plug-and-Play specification. The resulting EIA rack is 600 mm/23.6" deep.
Dedicated rear cable channel
The cable port has a capacity of up to 30 cables and is situated perfectly for ground or under-floor cabling. -
Integrated heat removal
High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment. -
Integrated power strip
Provided with a power strip which has 3 available IEC receptacles, 3 NEMA equipment power cords, 1 NEMA input cord and 1 Schuko input cord -
Removable lockable rear panel
Provides customers with easy accessibility to equipment and allows equipment to be installed without powering off.
- APC NetShelter CX Mini - rack - 12U
- Product Type
- Rack
- Rack Type
- Cabinet
- Built-in Devices
- Power distribution unit
- Package Content
- 2 fans, brush strip, front door, rear door, keys, 3 outlet power distribution strip, 3 power cables, 4 casters
- Grey, oak
- Height (Rack Units)
- 12U
- 69 cm x 93 cm x 70 cm
- 75 kg
- Soundproof enclosure, lockable front door, lockable rear door
- 2-year warranty
- Product Type
- Rack
- Rack Type
- Cabinet
- Built-in Devices
- Package Content
- 12U
- 69 cm
- 93 cm
- 70 cm
- 75 kg
- Grey, oak
- Weight Limit
- 85 kg
- RoHS
- TAA Compliant
- Limited warranty: - 2 years
APC Rackmount Rail Kit | In Stock | £92.45 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,479.34 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,896.57 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,371.97 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.21 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.80 |
APC Smart-UPS 750VA LCD 230V | In Stock | £351.93 |
