APC NetShelter CX Mini 12U Vertical Mounting Rail Kit
Quicklinx: C6HNWS00 Mfr#: AR4000MV12U
This 12 U vertical mounting rail kit bolts into pre-existing holes in the Netshelter CX mini to convert the basic enclosure into a 12 U rack enclosure with a fixed rack depth of 600 mm (26").
  • Quick install vertical mounting rail kit
    Using pre-existing holes and supplied hardware, these vertical mounting rails fit quickly and conveniently into place, transforming the CX Mini into a 12U Rack Enclosure
APC NetShelter CX Mini 12U Vertical Mounting Rail Kit rack rail kit - 12U
Rack rail kit
Height (Rack Units)
12U
12 cm x 5.6 cm x 53.6 cm
1.1 kg
Rack rail kit
Height (Rack Units)
12U
12 cm
5.6 cm
53.6 cm
1.1 kg
RoHS, REACH
