APC NetShelter CX 24U Secure Soundproofed Server Room in a Box
Quicklinx: 8D0HWS00 Mfr#: AR4024IA
Specialized enclosures with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
  • Integrated heat removal
    High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment
  • Integrated power distribution
    Provided with a rack power distribution unit servers and other equipment are ready for deployment
  • Light oak veneer finish
    The enclosure blends discretely into almost any office environment
  • Six vertical 0U accessory channels
    Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space
  • Dedicated rear cable access point
    The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling
  • Acoustic foam lining for noise dampening
    Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment
  • Adjustable equipment mounting rails
    The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in
  • Removable side panels
    Provides customers with easy accessibility to equipment
APC NetShelter CX - rack - 24U
Rack
Built-in Devices
Power distribution unit
Light oak
Rack Size
19"
Height (Rack Units)
24U
75 cm x 113 cm x 128.5 cm
170 kg
Wheels, key lock
Rack
Built-in Devices
Rack Size
19"
Height (Rack Units)
24U
75 cm
113 cm
128.5 cm
170 kg
Light oak
Weight Limit
280 kg
Wheels, key lock
RoHS
Limited warranty: - 2 years
Sound Emission
18 dBA
