Specialized enclosures with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
Integrated heat removal
High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment -
Integrated power distribution
Provided with a rack power distribution unit servers and other equipment are ready for deployment -
Light oak veneer finish
The enclosure blends discretely into almost any office environment -
Six vertical 0U accessory channels
Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space -
Dedicated rear cable access point
The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling -
Acoustic foam lining for noise dampening
Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment -
Adjustable equipment mounting rails
The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in -
Removable side panels
Provides customers with easy accessibility to equipment
- APC NetShelter CX - rack - 18U
- Product Type
- Rack
- Built-in Devices
- Power distribution unit
- Light oak
- Rack Size
- 19"
- Height (Rack Units)
- 18U
- 75 cm x 113 cm x 101.5 cm
- 138 kg
- Wheels, key lock
- 2-year warranty
- Product Type
- Rack
- Built-in Devices
- Rack Size
- 19"
- 18U
- 75 cm
- 113 cm
- 101.5 cm
- 138 kg
- Light oak
- Weight Limit
- 310 kg
- Wheels, key lock
- Plug and Play, RoHS
- Limited warranty: - 2 years
