APC NetShelter CX 18U Secure Soundproofed Server Room in a Box
Quicklinx: CQB0WS00 Mfr#: AR4018IA
Depth (mm): 113cm
Width (mm): 75cm
£3,068.86 ex VAT
£3,682.63 inc VAT
Specialized enclosures with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
  • Integrated heat removal
    High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment
  • Integrated power distribution
    Provided with a rack power distribution unit servers and other equipment are ready for deployment
  • Light oak veneer finish
    The enclosure blends discretely into almost any office environment
  • Six vertical 0U accessory channels
    Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space
  • Dedicated rear cable access point
    The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling
  • Acoustic foam lining for noise dampening
    Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment
  • Adjustable equipment mounting rails
    The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in
  • Removable side panels
    Provides customers with easy accessibility to equipment
APC NetShelter CX - rack - 18U
Rack
Built-in Devices
Power distribution unit
Light oak
Rack Size
19"
Height (Rack Units)
18U
75 cm x 113 cm x 101.5 cm
138 kg
Wheels, key lock
Rack
Built-in Devices
Rack Size
19"
Height (Rack Units)
18U
75 cm
113 cm
101.5 cm
138 kg
Light oak
Weight Limit
310 kg
Wheels, key lock
Plug and Play, RoHS
Limited warranty: - 2 years
CQB0 APC 750VA Line interactive rack mt In Stock £640.13
CQB0 APC Basic Rack-Mount PDU - power distribution strip In Stock £197.28
CQB0 APC 1U Horizontal Cable Organiser In Stock £54.86
CQB0 APC Smart-UPS SC 450VA 1U In Stock £280.73
CQB0 APC Rackmount Rail Kit In Stock £91.52
CQB0 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £263.71
CQB0 APC Rack PDU Basic Zero U 16A 208/230V In Stock £291.90
CQB0 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £280.82
CQB0 APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,190.34
CQB0 APC Cable Managers (Qty 10) In Stock £35.29
CQB0 APC 2U Horizontal Cable Organizer In Stock £57.58
CQB0 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,335.09
CQB0 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,668.18
CQB0 APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch In Stock £1,908.35
CQB0 APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,479.34
CQB0 APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,911.61
CQB0 APC Blanking Panel Kit In Stock £107.35
CQB0 APC 1U Blanking Panel Kit In Stock £33.57
CQB0 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.06
CQB0 APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,382.93
CQB0 APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,640.61
CQB0 APC Smart-UPS SRT 2200VA RM 230V In Stock £1,762.09
CQB0 APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,751.64
CQB0 APC Metered Rack PDU In Stock £829.13
CQB0 APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,195.38
CQB0 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £730.21
CQB0 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,070.54
CQB0 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.21
CQB0 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £644.38
CQB0 APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £600.82
CQB0 APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £716.93
CQB0 APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £899.73
CQB0 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £158.04
CQB0 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £79.41
CQB0 APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,518.44
CQB0 APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,125.33
CQB0 APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,918.26
CQB0 APC Smart-UPS 750VA RM 230V SmartConnect In Stock £526.43
CQB0 APC Smart-UPS 750VA LCD 230V In Stock £358.10
Depth (mm): 113cm
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: £1500+
