This product is a specialized enclosure with integrated cooling, noise dampening, and power distribution for server and network applications in office environments.
Integrated heat removal
High efficiency fan modules remove heat and eliminate the need to purchase a costly cooling unit for your IT equipment -
Integrated power distribution
Provided with a rack power distribution unit servers and other equipment are ready for deployment -
Six vertical 0U accessory channels
Provides multiple mounting locations for cable management accessories and rack PDUs without using critical equipment space -
Dedicated rear cable access point
The cable port has a capacity of up to 400 cables and is situated perfectly for ground or under-floor cabling -
Acoustic foam lining for noise dampening
Superior noise reduction of installed IT equipment allowing the enclosure to be placed in a quiet environment -
Adjustable equipment mounting rails
The equipment mounting rails, front and rear, are fully adjustable for various mounting depths, for rear-facing equipment mounting or additional clearance from the front door. Maximum rack depth 88 cm/34.6 in. Minimum rack depth 12 cm/4.7 in -
Removable side panels
Provides customers with easy accessibility to equipment -
Compatibility with enhanced enclosure access security options
Enclosure is provided standard with front, rear, side locking components and is designed for compatibility with increased security options such as combination-style and electronic swipe access handles
- APC NetShelter CX - rack - 18U
- Product Type
- Rack
- Package Content
- Side panels, keys, PDU (Power Distribution Unit), levelling feet, casters
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 18U
- 75 cm x 113 cm x 101.5 cm
- 131 kg
- Noise reduction, lockable, built-in cooling fan
- 2-year warranty
- Product Type
- Rack
- Package Content
- Rack Size
- 19"
- 18U
- 75 cm
- 113 cm
- 101.5 cm
- 131 kg
- Black
- Weight Limit
- 830 kg
- Limited warranty: - 2 years
