Product
APC Mobile Power Pack 3000mAh Li-ion cylinder - Titanium
Quicklinx: BL7WWS00 Mfr#: M3TM-EC
Extends the Mobile Power Pack's battery life by automatically shutting down when the connected devices have completely charged.
Push-button activated LED display provides battery charge status.
  • Efficient charging
  • LED battery charge indicator
APC Mobile Power Pack - power bank - Li-Ion
Power bank
3.2 cm x 7.2 cm x 2.2 cm
140 g
Output Connector Type
USB
5 V
Voltage Provided
5 V
Lithium Ion - 3000 mAh
Power Device Details
- 4 pin USB Type A - 5 V - 1 A
1 year warranty
Power bank
3.2 cm
7.2 cm
2.2 cm
140 g
Enclosure Colour
Titanium
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Max Electric Current
1 A
Overload protection, LED indicator, short circuit protection, overcharging protection, overheat protection, over-current protection, overdischarging protection
Lithium Ion
3000 mAh
Recharge Time
4 hour(s)
CB, FCC Part 15 B, RoHS, IEC 60950-1, EN 60950-1, REACH, IEC 62133, UN38.3
Limited warranty - 1 year
BL7W C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
BL7W C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
BL7W C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.76
BL7W C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
BL7W C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
BL7W C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.28
BL7W C2G USB Superbooster Extender Kit In Stock £37.81
BL7W C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
BL7W C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
