Product
APC MGE Galaxy 3500 40kVA 400V with 4 Battery Modules  Start-up
Quicklinx: 86DBWS00 Mfr#: G35T40KH4B4S
Type: UPS
Power Rating: 32kW
£9,689.70 ex VAT
£11,627.64 inc VAT
MGE Galaxy 3500 offers centralized 3 phase power protection with the reliability of the MGE product family. Ideal for commercial and technical facilities as well as industrial applications, the MGE Galaxy 3500 includes dual-mains input, automatic and maintenance bypasses, and scalable runtime with hot-swappable batteries for increased availability. The parallel capability for redundancy and capacity, and extended run battery frames provide increased flexibility. Low cost of ownership is achieved through best-in-class efficiency and a reduction in rating of electrical infrastructure - wires, transformers, and generators. The built in network management card with temperature monitoring provides remote monitoring and management through a simple web/SNMP interface. Serviceability is greatly enhanced by user-replaceable batteries, front access servicing. All these features make the MGE Galaxy 3500 the easiest UPS in its class to deploy, manage and maintain.
  • Dual mains input
    Increases availability by allowing the UPS to be connected to two separate power sources.
  • Generator compatible
    Ensures clean, uninterrupted power to protected equipment when generator power is used.
  • Parallel-redundant capable
    Power the connected equipment with multiple UPSs to increase system redundancy.
  • Parallel-capacity capable
    Increases total power capacity by using multiple UPSs simultaneously.
  • Advanced electrical features
    Excellent power conditioning, very low harmonic distortion through IGBT rectifier, input power factor correction, and high efficiency.
  • Frequency and voltage regulation
    Gives higher application availability by correcting poor frequency and voltage conditions without using the battery.
  • Automatic internal bypass
    Supplies utility power to the connected loads in the event of a UPS overload condition or fault.
  • Input power factor correction
    Minimizes installation costs by enabling the use of smaller generators and cabling.
  • Excellent footprint
    Small UPS footprint provides maximum usage of valuable electrical room floorspace.
MGE Galaxy 3500 with 4 Battery Modules - UPS - 32 kW - 40000 VA
UPS - external
662 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 380/400/415 V ± 5%
Power Capacity
32 kW / 40000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G)
Output connectors
1 x hardwire 4-wire (3PH + G) , 1 x hardwire 5-wire (3PH + N + G) , 1 x Terminal Block (Screw)
Lead Acid expandable
Batteries Qty
4
Run Time (Up To)
5.5 min at full load
RS-232
Remote Management Protocol
SNMP, HTTP
Bolt down brackets
52.3 cm x 83.8 cm x 149 cm
1 year warranty
UPS - external
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 304 - 477 V
Input Voltage Range (Adjustable)
AC 340 - 460 V
Frequency Provided
47 - 53 Hz
Input Wiring
3-phase
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 380/400/415 V ± 5% - 47 - 53 Hz
Power Capacity
32 kW / 40000 VA
Output Waveform
Sinewave
Expandable
Quantity
4
Lead Acid
Run Time (Up To)
Recharge Time
5 hours
Remote Management Interface
RS-232
SNMP, HTTP
1 x management (RS-232) , 1 x EPO (emergency power off)
Expansion Slots
SmartSlot
Bolt down brackets
Serial cable - external
Audible alarm, emergency power off, LCD display, built-in maintenance bypass, built-in static bypass
ISO 9001, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, EN 50091-2, IEC 62040-3, IEC 62040-1-1
Software Included
Drivers & Utilities
Limited warranty - 1 year
0 - 95%
Sound Emission
55 dBA
52.3 cm
83.8 cm
149 cm
662 kg
Shipping Width
65 cm
Shipping Depth
106 cm
Shipping Height
164 cm
Shipping Weight
692 kg
Type: UPS
Power Rating: 32kW
Brand: APC
Price Range Ex VAT: 1500+
