APC Horizontal Cable Manager 2U Single Side with Cover
CLEARANCE!
Clearance
Price Drop
Quicklinx: 9HN2WS00 Mfr#: AR8600A
Horizontal cable managers include double-sided configuration hardware to install alike horizontal cable managers back-to-back for double-sided applications.
Cable managers feature high capacity slim cable fingers to provide maximum capacity at every rackspace unit and a rigid design to decrease deflection when cables are routed in/out of the cable manager channel.
  • Cable protection and pass-through
    Smooth plastic fingers provide proper bend radius
  • Double-sided capable
    Horizontal cable managers include double-sided configuration hardware to install (2) alike horizontal cable managers back-to-back for double-sided applications
  • Trouble-free access
    Covers with snap hinges provide trouble-free access to cables
  • High capacity cable finger design
    Cable managers feature high capacity slim cable fingers to provide maximum capacity at every rack space unit and a rigid design to decrease deflection when cables are routed in/out of the cable manager channel
APC Horizontal Cable Manager Single-Sided with Cover - rack cable management kit - 2U
Rack cable management kit
Rack Size
19"
Height (Rack Units)
2U
8.8 cm x 46.5 cm x 10.9 cm
1.02 kg
Horizontal orientation
Smart-UPS X 3000VA Short Depth Tower/Rack LCD
Rack Size
19"
Height (Rack Units)
2U
8.8 cm
46.5 cm
10.9 cm
1.02 kg
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
APC Smart-UPS X 3000VA Short Depth Tower/Rack LCD
