APC Cable Trough 750mm
Quicklinx: 79F1WS00 Mfr#: AR8571
Safety protection against electric shock and reduction of EMI emissions - NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment.
  • Protective grounding provisions
    Safety protection against electric shock and reduction of EMI emissions. NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment
APC cable management trough
Cable management trough
74.7 cm x 31.7 cm x 19.1 cm
6.9 kg
NetShelter SX
74.7 cm
31.7 cm
19.1 cm
6.9 kg
Mounting Kit
Included
UL, RoHS, REACH
APC NetShelter SX
