Safety protection against electric shock and reduction of EMI emissions - NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment.
Protective grounding provisions
Safety protection against electric shock and reduction of EMI emissions. NetShelter Enclosures incorporate a series of ground studs within each enclosure, providing adequate means for grounding all loose sheet metal panels and/or internally rack-mounted equipment
- APC - cable management trough
- Product Type
- Cable management trough
- Black
- 74.7 cm x 31.7 cm x 19.1 cm
- 6.9 kg
- 2-year warranty
- Designed For
- NetShelter SX
- Product Type
- 74.7 cm
- 31.7 cm
- 19.1 cm
- 6.9 kg
- Black
- Mounting Kit
- Included
- UL, RoHS, REACH
- Limited warranty: - 2 years
- Designed For
- APC NetShelter SX
