Product
APC Basic Rack-Mount PDU 1.8 kW
Quicklinx: 9P8JWS00 Mfr#: AP9562
Type: PDU
Power Rating: 1.8kW
£109.30 ex VAT
£131.16 inc VAT
APC offers a wide variety of Basic Rack Power Distribution Units (PDUs), which allow users to distribute power outlets to rack-mount equipment. Horizontal and vertical units are available as well as a variety of power inputs and outputs to fit most power environments. Basic Rack PDUs are InfraStruXure Certified and mount vertically, without tools in the rear channel of a NetShelter VX.
APC Basic Rack-Mount PDU - power distribution strip - 1.8 kW
Power distribution strip - rack-mountable
Cord Length
3.7 m
Rack Size
19" - 1U
2.5 kg
Input Voltage
AC 120 V
Output Voltage
AC 120 V
Power Capacity
1.8 kW
Input Connectors
1 x power NEMA 5-15
Output connectors
10 x power NEMA 5-15
44.7 cm x 5.7 cm x 4.5 cm
2 years warranty
P/N: AR3100, SU1400RMXLB3U, SU1400RMXLB3U-TRAD, SU1400RMXLB3U-TU, SU2200RMXL3U-TU, SU3000RMNET-1EW, SU5000R5TBXFMR, SU5000R5TBXFMR-TU, SUA1000RM2U-TU, SUA1000RMUS, SUA1500R2X93-TU, SUA1500RMUS, SUA3000, SUA3000RM2U-TU, SUA750RMJ1UB, SUM3000RMXL2U, SUM3000RMXL2U-TU, SURTA3000XL, SURTA3000XL-TU
Height (Rack Units)
1U
Rack Size
19"
Cord Length
3.7 m
Input Voltage
AC 120 V
Input Voltage Range
AC 100 - 120 V
Input Connectors
1 x power NEMA 5-15
Output Voltage
AC 120 V
Max Electric Current
15 A
Power Capacity
1.8 kW
Circuit Protection
Circuit breaker
Power cable - integrated - 3.7 m
Rack Mounting Kit
Included
UL, cUL, UL 1363
Limited warranty - parts and labour - 2 years , Limited warranty - replacement - 2 years
-5 °C
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
0 - 95%
Humidity Range Storage
0 - 95%
44.7 cm
5.7 cm
4.5 cm
2.5 kg
P/N: AR3100, SU1000R2BX120, SU1000RM, SU1000RM2U, SU1000RMNET, SU1400R2BX120, SU1400R2X122, SU1400RM, SU1400RM2U, SU1400RMBX120, SU1400RMNET, SU1400RMX176, SU1400RMXL3U, SU1400RMXLB3U, SU1400RMXLB3U-TRAD, SU1400RMXLB3U-TU, SU1400RMXLNET, SU1500RMX155, SU2000R3X155, SU2200R3BX120, SU2200R3X106, SU2200R3X147, SU2200R3X152, SU2200R3X152-TU, SU2200R3X167, SU2200RM, SU2200RM3U, SU2200RMNET, SU2200RMXL3U, SU2200RMXL3U-TU, SU2200RMXLNET, SU2200RMXLTNET, SU2200RMXLTX153, SU3000R3BX120, SU3000R3BX135, SU3000R3X145, SU3000R3X145-TU, SU3000RM3U, SU3000RMJ3U, SU3000RMNET, SU3000RMNET-1EW, SU3000RMT3U, SU3000RMTX136, SU3000RMX93, SU3000RMXL3U, SU5000R5TBXFMR, SU5000R5TBXFMR-TU, SU5000RMT5U, SU5000RMT5U-TU, SU5000RMT5UXFMR, SU700R2BX120, SU700R2BX120-TU, SU700RM2U, SUA1000RM2U, SUA1000RM2U-TU, SUA1000RMUS, SUA1500R2X93-TU, SUA1500RMUS, SUA3000, SUA3000RM2U, SUA3000RM2U-TU, SUA750RM1U, SUA750RM2U, SUA750RM2U-TU, SUA750RMJ1UB, SUM3000RMXL2U, SUM3000RMXL2U-TU, SURTA3000XL, SURTA3000XL-TU
Type: PDU
Power Rating: 1.8kW
Brand: APC
Price Range Ex VAT: 100 - 150
