APC BACK UPS PRO BR900MI 900VA 6 Outlets
Quicklinx: FLTZWS00 Mfr#: BR900MI
Power Rating: 540Watt
£198.90 ex VAT
£238.68 inc VAT
The APC Back-UPS Pro models provide premium battery backup and surge protection. Ideal for home or small office electronics, networking devices, gaming PCs and consoles. APC Back-UPS Pro models provide sinewave output, USB charging ports for your mobile devices, and increased runtime for your critical electronics.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR).
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models).
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines.
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models).
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
APC Back-UPS Pro BR900MI - UPS - 540 Watt - 900 VA
UPS - external
7 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 8%
Power Capacity
540 Watt / 900 VA
Input Connectors
1
Output connectors
6 x power (UPS and surge)
Lead Acid
Run Time (Up To)
3 min at full load
USB
9.1 cm x 31 cm x 19 cm
2-year warranty (European Union - 3 years)
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 176 - 294 V
Frequency Provided
50/60 Hz ± 1Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
1
Output Voltage
AC 230 V ± 8% - 50/60 Hz
Power Capacity
540 Watt / 900 VA
Dataline Surge Protection
Ethernet 10/100/1000Base-T - RJ-45 - 1 input line / 1 output line , Phone line - 1 input line / 1 output line
Output Waveform
Stepped approximation to a sinewave
Surge Energy Rating
557 Joules
Circuit Protection
Circuit breaker
Power Factor (PF)
0.6
Lead Acid
Run Time (Up To)
3 min at full load , 11.4 min at half load , 8 min at 335 Watts , 14 min at 240 Watts , 34 min at 119 Watts , 105 min at 40 Watts
Recharge Time
12 hours
Remote Management Interface
USB
Management (USB)
Power cable 1.83 m , USB cable
Equipment Protection Value
150000 Euros
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, dataline protection
TUV GS, EMC, IP20, KETI, EAC, RCM, TISI, CB 60950
Software Included
APC PowerChute Personal Edition
Limited warranty - replace or repair - 2 years , European Union: limited warranty - replace or repair - 3 years
9.1 cm
31 cm
19 cm
7 kg
Shipping Width
44 cm
Shipping Depth
14.3 cm
Shipping Height
25.5 cm
Shipping Weight
8 kg
FLTZ APC Service Pack 1 Year Warranty Extension In Stock £42.84
FLTZ APC Service Pack 3 Year Warranty Extension In Stock £97.06
Brand: APC
