APC Back-UPS ES SurgeArrest plus Battery Backup BS1363
Quicklinx: 4V4DWS00 Mfr#: BE325-UK
Type: UPS
Power Rating: [N/A]
43 in stock
£86.69 ex VAT
£104.02 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
APC SurgeArrest 325 - UPS - 325 VA
UPS - external
4 kg
United Kingdom
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
325 VA
Input Connectors
1
Output connectors
4 x power
Lead Acid
Battery Form Factor
Internal
11.5 cm x 36.4 cm x 9.5 cm
UPS - external
Battery Enclosure Type
Internal
United Kingdom
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Frequency Provided
50 Hz
Frequency Required
47 - 53 Hz
Input Connectors
1
4 x power
Output Voltage
AC 230 V 50 Hz
Power Capacity
325 VA
Dataline Surge Protection
Phone line - RJ-11
Surge Suppression
Lead Acid
Recharge Time
16 hours
Power cable - integrated
IEC 60950, EN55022 Class B, EN 50091-2
0 - 95%
11.5 cm
36.4 cm
9.5 cm
4 kg
4V4D APC Replacement Battery Cartridge #47 In Stock £28.50
Resources
The following resources are available for the APC Back-UPS ES SurgeArrest plus Battery Backup BS1363
Type: UPS
Power Rating: [N/A]
Brand: APC
Stock Status: In stock
