APC Back-UPS 500VA,AVR, IEC outlets
Quicklinx: 989SWS00 Mfr#: BX500CI
Type: UPS
Power Rating: 500VA
More than 50 in stock
£57.84 ex VAT
£69.40 inc VAT
BX500CI Features
Battery failure notification - Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
Resettable circuit breaker - Easy recovery from overloads; no need to replace a fuse.
Boost Automatic Voltage Regulation (AVR) - Preserves battery life and maximizes runtime by correcting low voltages without discharging the battery.
Automatic self-test - Periodic battery self-test ensures early detection of a battery that needs to be replaced.
Adjustable voltage-transfer points - Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation.
Adjustable voltage sensitivity - Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications.
Audible alarms - Provides notification of changing utility power and UPS power conditions.
Safety-agency approved - Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
LED status indicators - Quickly understand unit and power status with visual indicators.
Type: UPS
Power Rating: 500VA
Brand: APC
Price Range Ex VAT: 50 - 100
