APC Back-UPS BX series is a cost-effective power protection solution for home and home office environments. The series comprehensive VA range with premium features further enables single UPS capabilities.
PowerChute Personal Edition OS Compatibility
This software supports numerous operating systems and processors. lt/ /a gt/ -
Automatic Voltage Regulation (AVR)
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment. -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines. -
USB connectivity
Provides management of the UPS via a USB port (not available on all models).
- APC Back-UPS BX Series BX2200MI - UPS - 1200 Watt - 2200 VA
- UPS - external
- 12.3 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 10%
- Power Capacity
- 1200 Watt / 2200 VA
- Input Connectors
- 1 x power IEC 60320 C19
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid - 9 Ah
- Batteries Qty
- 2
- Run Time (Up To)
- 8.5 min at half load
- 14 cm x 39 cm x 19 cm
- 2-year warranty
- UPS - external
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 140 - 300 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 10% - 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network - RJ-45 - 1 input line / 1 output line
- Output Waveform
- Stepped approximation to a sinewave
- Surge Energy Rating
- 273 Joules
- Circuit Protection
- Fuse
- Quantity
- 2
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 9 Ah
- Run Time (Up To)
- 8.5 min at 50% load , 1 min at full load
- Recharge Time
- 8 hours
- Transfer Time
- 6 ms
- Maintenance free, sealed
- 1 x USB
- Cables Included
- Power cable - external - 1.2 m
- Audible alarm, Automatic Voltage Regulation (AVR)
- CB, IEC 62040-2, IP20, IEC 62040-1, EN 62040-1
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - replace or repair - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 14 cm
- 39 cm
- 19 cm
- 12.3 kg
- Shipping Width
- 23.5 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 29.7 cm
- Shipping Weight
- 13.3 kg
