APC APC POWERCORD C19 TO C20 1.8M
Quicklinx: 7FP3WS00 Mfr#: ap8716s
Length: 1.8m
£143.86 ex VAT
£172.63 inc VAT
Free up space and secure power cords between rack-mount PDUs and attached IT equipment with this exclusive easy-to-use cord retention method. While these cords will fit into any standard IEC receptacle or power inlet; the "locking" feature is enabled only when used with APC AP8000 series Rack PDUs or IT equipment with built-in locking receptacles. These locking connectors reduce the probability of accidentally disconnecting cords and dropping loads.
APC power cable - 1.8 m
Power cable
Length
1.8 m
Connector
Power IEC 60320 C19
Connector (Second End)
Power IEC 60320 C20
Included Qty
6
Rated Voltage
AC 240 V
P/N: DLT3000RMI2U, SMT2200RMI2UC, SMX3000RMHV2UNC, SRT1500XLI, SRT2200RMXLI-NC, SRT2200XLI-KR, SRT3000RMXLI-NC, SRT5KRMXLIM, SRT6KRMXLIM, SURTD2200XLIM, SYA8K8RMI
Power cable
Included Qty
6
Rated Voltage
AC 240 V
Length
1.8 m
Connector
Power IEC 60320 C19
Power IEC 60320 C20
Length: 1.8m
Brand: APC
Price Range Ex VAT: 100 - 150
