APC 750VA Line interactive rack mt
Quicklinx: 2HS5WS00 Mfr#: SUA750RMI1U
Type: UPS
Power Rating: 480Watt
Hurry, only 1 left in stock!
£527.74 ex VAT
£633.28 inc VAT
APC's slim line rack-mount Smart-UPS delivers premium uninterruptible power and the most advanced performance features available. With PowerChute plus software the uninterruptible power supply (UPS) will safely store data and shut down your network operating system before the battery is fully discharged, whether you're there or not. SmartSlot internal accessory slot allows you to install optional accessories to enhance the performance of your UPS. Additionally, the APC NetShelter enclosure provides security, flexibility and proper management of all your rack-mount devices.
  • Front-access servicing
    Simplifies installation and UPS maintenance while minimizing space requirements.
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models).
APC Smart-UPS RM 750VA USB - UPS - 480 Watt - 750 VA
UPS - rack-mountable
Rack Size
1U
21.8 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
480 Watt / 750 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
7.1 min at full load
48.3 cm x 66 cm x 4.4 cm
P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3340G, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBWL0356A
Height (Rack Units)
1U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
480 Watt / 750 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Lead Acid
Run Time (Up To)
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
USB cable - external , Serial cable - external
Rack Mounting Kit
Included
LED display, audible alarm
C-Tick, GOST, PCBC, UL 1449, VDE
Software Included
APC PowerChute Business Edition
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
48.3 cm
66 cm
4.4 cm
21.8 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP9290, AR100, AR100HD, AR202, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBWL0356A
2HS5 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £23.90
2HS5 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £39.91
2HS5 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £43.09
2HS5 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £210.90
2HS5 APC NETSHELTER SX 24U In Stock £947.66
2HS5 APC Temperature and Humidity Sensor In Stock £123.67
2HS5 APC APC CABLE USB A In Stock £46.13
2HS5 APC Replacement Battery Cartridge In Stock £221.97
2HS5 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £47.00
2HS5 APC Power Cable (pack of 6) 1.22m In Stock £71.60
2HS5 APC Dry Contact I/O SmartSlot Card In Stock £144.22
2HS5 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £105.16
2HS5 APC Extended Warranty Service Pack 3 Year In Stock £124.94
2HS5 APC Service Pack 1 Year Warranty Extension In Stock £58.66
2HS5 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £47.34
2HS5 APC Switched PDU 10A 0U C13x16 In Stock £980.37
2HS5 APC Rack Automatic Transfer Switch AP4421 Redundant Switch In Stock £593.88
2HS5 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £556.71
Resources
The following resources are available for the APC 750VA Line interactive rack mt
Type: UPS
Brand: APC
Price Range Ex VAT: £500 - £750
Stock Status: In stock
