AORUS Thunder M7 MMO Gaming Mouse
Quicklinx: 9PGTWS00 Mfr#: GM-THM7
MMO GAMING MOUSE
  • 16 fully-programmable gaming buttons
  • Fine-tuned ergonomics for MMORPG game titles
  • Advanced 8200dpi Laser Sensor
  • Ultra-durable 20 million clicks Omron switch
Fine-tuned Ergonomics
Create for MMORPG game titles, well located buttons offer instant execution of the gaming commands.
16 fully-programmable Gaming Buttons
All keys on THUNDER M7 are programmable via AORUS macro engine to ensure the maximal flexibility for customizing personal skillsets.
Top-of-the-line Gaming Laser Sensor
Advanced laser sensor supporting up to 8200dpi resolution and 150ips lightning fast tracking speed ensures efficient and smooth movement on your multi-screens or the most high resolution monitors.
On-the-fly DPI Switching
800/1600/3200/5600DPI adjustable switch with synchronized indicator for quick on the-fly DPI adjustment.
20 million clicks lifetime Omron switch
Ultra-durable 20 million clicks Omron switches not only extend the durability and also perfect the clicking response.
Built-in AORUS Macro Engine
Profile switch at your fingertips enables you to switch between 5 different gaming profiles. Up to 70 macros memorization for the gamer on the go.
  • Fully programmable gaming buttons
    All keys on the THUNDER M7 are programmable to ensure maximal flexibility and customization of your personal skills.
  • Gaming laser sensor
    Advanced laser sensor and lightning-fast tracking speed ensures efficient and smooth movement on your high-resolution monitors.
  • On-the-fly DPI switching
    Adjustable switch with synchronized indicator for quick on the-fly DPI adjustment.
AORUS THUNDER M7 - mouse - USB - black
Mouse
Wired - USB
7 cm x 11.6 cm x 4.4 cm
Movement Detection Technology
Laser
Buttons Qty
16
Movement Resolution
8200 dpi
Performance
150 inches per second
Scrolling wheel, on-the-fly DPI switching
Cable Length
1.8 m
Microsoft Windows Vista / XP / 7 / 8
Mouse
7 cm
11.6 cm
4.4 cm
Input Device
Wired
USB
Laser
Buttons Qty
16
Movement Resolution
8200 dpi
Performance
Cable Length
1.8 m
BSMI, FCC, KCC
Software Included
AORUS Macro Engine
