AOC Value I2769VM 27" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: 96GXWS00 Mfr#: i2769Vm
This Full HD monitor blows the contents of your Android devices up to an impressive size: With the innovative MHL interface (Mobile High-Definition Link) high-resolution photos, videos and games can be displayed directly from a smartphone or tablet PC on the huge 68.6 cm (27?) screen. A practical side effect: the mobile gadgets get charged at the same time. The LED model utilizes the high-quality IPS display technology, which, besides providing strong contrast and brightness, stands for exceptionally good color fidelity and viewing angle stability. This monitor will be a big stage for your photos and videos!
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • MHL Connection
    Mobile High-Definition Link (MHL) technology lets you mirror the content from your portable devices directly on this display. Use an MHL cable to connect your smartphone or tablet and bring all your entertainment to life on the large monitor screen with full digital sound. Relax and enjoy your games, movies, photos and apps on the big screen while charging your mobile device at the same time.
  • Display Port
    The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
AOC I2769VM - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 90 - 240 V (50/60 Hz)
62.2 cm x 13 cm x 44.9 cm
4.99 kg
Environmental Standards
ENERGY STAR Qualified
GOST, FCC, RoHS, ISO 9241-307, TUV Bauart, EuP, NRTL
3-year warranty
Display Type
Energy Class
Class A
35 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 77 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
4.99 kg
2 x HDMI , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
Input Voltage
24 W
Power Consumption (Typical)
43 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
96GX C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
