This Full HD monitor blows the contents of your Android devices up to an impressive size: With the innovative MHL interface (Mobile High-Definition Link) high-resolution photos, videos and games can be displayed directly from a smartphone or tablet PC on the huge 68.6 cm (27?) screen. A practical side effect: the mobile gadgets get charged at the same time. The LED model utilizes the high-quality IPS display technology, which, besides providing strong contrast and brightness, stands for exceptionally good color fidelity and viewing angle stability. This monitor will be a big stage for your photos and videos!
IPS Panel
No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
MHL Connection
Mobile High-Definition Link (MHL) technology lets you mirror the content from your portable devices directly on this display. Use an MHL cable to connect your smartphone or tablet and bring all your entertainment to life on the large monitor screen with full digital sound. Relax and enjoy your games, movies, photos and apps on the big screen while charging your mobile device at the same time. -
Display Port
The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
- AOC I2769VM - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 90 - 240 V (50/60 Hz)
- Black
- 62.2 cm x 13 cm x 44.9 cm
- 4.99 kg
- Environmental Standards
- ENERGY STAR Qualified
- GOST, FCC, RoHS, ISO 9241-307, TUV Bauart, EuP, NRTL
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 35 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 77 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP, Eco-Mode, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Screen+
- Black
- 4.99 kg
- 2 x HDMI , VGA , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable , 1 x HDMI cable , 1 x audio cable
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 43 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
