AOC Value i2080Sw 19.5" 1440x900 5ms VGA LED Monitor
Quicklinx: D6W4WS00 Mfr#: i2080Sw
Diagonal Size: 19.5in
Max Resolution: 1440 x 900
Response Time: 5ms
Interfaces: VGA (HD-15)
£60.43 ex VAT
£72.51 inc VAT
The 19.5-inch AOC I2080SW handles all your home computing needs with excellent performance and sharp, clear imagery. Featuring an IPS panel, you'll enjoy accurate colors, wide viewing angles and impressive picture quality, whether you're editing photos or just surfing the web. Fast response time eliminates blurring to deliver smooth action sequences for more exciting movies and games. This versatile home display makes the perfect addition to your home office or living room, and the integrated VESA mount also gives you the possibility to hang it on the wall. With the built-in VGA connector, you can hook up your computer and get started fast.
AOC Value i2080Sw - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
45.46 cm x 19 cm x 37.5 cm
2.14 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, FCC, RoHS, REACH, EuP, EAC
3-year warranty
Display Type
Diagonal Size
19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
I-Menu
45.46 cm x 19 cm x 37.5 cm - with stand
2.14 kg
VGA
Mechanical
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
ENERGY STAR Certified
Limited warranty - 3 years
AOC Value i2080Sw 19.5 Bundle deal on AOC Value i2080Sw 19.5" 1440x900 5ms VGA LED Monitor
£159.60
Response Time: 5ms
Brand: AOC
Price Range Ex VAT: 50 - 100
