AOC Style I2481FXH 23.8" 1920x1080 4ms VGA HDMI IPS Monitor
Quicklinx: BVWJWS00 Mfr#: I2481FXH
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Interfaces: HDMI, VGA (HD-15)
27 in stock
£107.93 ex VAT
£129.51 inc VAT
Amazing picture quality, stunning design and a minimal footprint make the 23.8-inch I2481FXH a smart addition to your home or office. This display's ultra-slim 7.5mm profile and eye-catching base are sure to get people talking. The on-screen performance is just as impressive - the AH-IPS panel provides virtually borderless viewing and uniform colors from nearly any angle. With a built-in headphone jack and HDMI (x2) and VGA connectors, this monitor is also ideal for using multiple devices like computers and game consoles. Flicker-free technology optimizes the brightness to reduce eye strain, no matter what you're doing.
Display Type
LCD monitor / TFT active matrix
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
21 W
Diagonal Size
23.8"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, i-Menu, e-Saver technology, Slim Design, Flicker Free technology
54.1 cm x 15 cm x 40.3 cm - with stand
3.1 kg
Audio line-out (mini-jack) , 2 x HDMI , VGA
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-3/+20
1 x VGA cable , 1 x HDMI cable
EAC
AC 100/120/230 V (50/60 Hz)
23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Environmental Standards
ENERGY STAR Certified
Limited warranty - 3 years
AOC Style I2481FXH 23.8 Bundle deal on AOC Style I2481FXH 23.8" 1920x1080 4ms VGA HDMI IPS Monitor
£207.10
BVWJ C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BVWJ C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.62
BVWJ C2G 5m Select High Speed HDMI with Ethernet In Stock £22.12
BVWJ C2G 10m Select High Speed HDMI with Ethernet In Stock £42.46
BVWJ C2G 15m Select High Speed HDMI with Ethernet In Stock £57.52
BVWJ C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 100 - 150
