AOC Q3279VWFD8 31.5" 2560x1440 5ms VGA DVI HDMI DisplayPort LED Monitor
Quicklinx: F58FWS00 Mfr#: Q3279VWFD8
A multi-purpose 31.5" Quad HD display, designed for gaming, entertainment, home use, and more. Comes with gaming enhancements like AMD FreeSync, AOC Shadow Control and Game Colour for better visual quality. For more general use, it also comes with Low Blue Light eye protection, Off Timer for power saving, and multiple digital inputs like Dual Link DVI and HDMI.
  • FreeSync technology
    AMD FreeSync delivers effortlessly smooth gameplay with fluid performance at virtually any frame rate. Finally you can put an end to frame tearing & stuttering ruining the game.
  • QHD - high resolution panel
    With 2560 x 1440 resolution, Quad HD (QHD) offers superior picture quality and sharp imagery that reveals the finest details. The widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size.
  • Shadow Control
    AOC Shadow Control enables fast adjustment of the in-game image to improve areas of the screen that are too dark or washed out, without affecting the rest of the screen.
  • Game Color
    With AOC Game color, adjust color saturation and gray level with 20 levels of detail for a better game experience.
  • Game Mode
    AOC's Game Mode allows fast changes to image settings & game presets.
  • 88% NTSC wide color gamut
    No more dull & under-saturated gaming: unleash the full spectrum of true-to-life colors with WCG.
  • Low blue light
    Reduce harmful blue light emissions with AOC's Low-Blue Technology.
  • Off timer
    To save power, a timer can be set to automatically turn off the monitor after a user-defined interval.
  • Digital inputs
    Dual Link DVI effectively doubles video bandwidth to support 144 Hz refresh rate. HDMI 1.4 is a popular digital video and sound connection standard DisplayPort 1.2 is capable of higher performance and convenience than older digital formats.
AOC Q3279VWFD8 - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class F
Energy Consumption per Year
67 kWh
Power Consumption (On mode)
29.4 W
Adaptive-Sync Technology
AMD FreeSync
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 (DisplayPort: 75 Hz, HDMI: 75 Hz, DVI: 60 Hz, VGA: 60 Hz)
Pixel Pitch
0.273 mm
Brightness
250 cd/m²
Contrast Ratio
1200:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Colour Gamut
88% (NTSC 1976)
Input Connectors
HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments
Tilt
72.96 cm x 15.32 cm x 53.3 cm
7 kg
BSMI, CCC, FCC, RoHS, KCC, cTUVus, KC, RCM, ISO9241-307
3-year warranty
Display Type
LED-backlit LCD monitor / IPS
Energy Class
Class F
67 kWh
Diagonal Size
31.5"
AMD FreeSync
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.273 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
88% (NTSC 1976)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, AOC Shadow Control, AOC Low-Blue Technology, AOC Game Color, AOC Game Mode
72.96 cm x 15.32 cm x 53.3 cm - with stand
7 kg
MHL / HDMI , VGA , DisplayPort , DVI (dual link) , Headphones (mini-jack)
Mechanical
Tilt
Tilt Angle
-3.5/+23.5
29.4 W
29.4 kWh/1000h
Power Consumption (Typical)
50 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Windows 10
Shipping Width
83.9 cm
Shipping Depth
64 cm
Shipping Height
18.3 cm
Shipping Weight
10.2 kg
Limited warranty - parts and labour - 3 years
