AOC Q2790PQU/BT 27" 2560x1440 4ms HDMI VGA DisplayPort LED Monitor
Quicklinx: D6WLWS00 Mfr#: Q2790PQU/BT
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£260.40 ex VAT
£312.48 inc VAT
The Q2790PQU is equipped with a QHD (2560 x 1440 pixels) IPS panel, delivering excellent color accuracy and a wide color gamut. Its ergonomic base in titanium finish complements the elegant 3-sided frameless design.
  • IPS panel
    No matter, if you are viewing photos, videos, a magazine layout in InDesign or playing your favorite game - AOC wants your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colors and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you - or your friends and co-workers sitting or standing next to you - are looking at the screen.
  • Height-adjustable stand
    AOC cares about your well-being. This is why this monitor offers height-adjustment possibilities, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Integrated speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
AOC Q2790PQU/BT - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
42 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
TUV GS, GOST, RoHS
3-year warranty
Display Type
Energy Class
Class B
61 kWh
42 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Power off timer, HDCP, Eco-Mode, 100% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, 90% NTSC (CIE 1976) colour gamut, borderless
Audio
Speakers
Output Power / Channel
2 Watt
VGA (HD-15) , 2 x HDMI , DisplayPort , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+25
Swivel Angle
330
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
TUV GS, GOST, RoHS
Security Slot Type
Kensington security slot
AC 100/240 V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years
AOC Q2790PQU/BT 27 Bundle deal on AOC Q2790PQU/BT 27" 2560x1440 4ms HDMI VGA DisplayPort LED Monitor
£359.57
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
