AOC Q2790PQU/BT 27" 2560x1440 4ms HDMI VGA DisplayPort LED Monitor
Quicklinx: D6WLWS00 Mfr#: Q2790PQU/BT
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£232.62 ex VAT
£279.14 inc VAT
The Q2790PQU is equipped with a QHD (2560 x 1440 pixels) IPS panel, delivering excellent color accuracy and a wide color gamut. Its ergonomic base in titanium finish complements the elegant 3-sided frameless design.
  • Three-Year Warranty
    AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • IPS Panel
    No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen.
  • QHD Resolution
    With 2560 x 1440 resolution, Quad HD (QHD) offers superior picture quality and sharp imagery that reveals the finest details. The widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size.
  • Frameless Design
    3-Sides frameless design of the monitor lets the user focus on the vivid display, and onlookers will enjoy the sleek and modern look from every angle.
  • Wide Colour Gamut
    When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
AOC Q2790PQU/BT - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
61 kWh
Power Consumption (On mode)
42 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
TUV GS, GOST, RoHS
3-year warranty
Display Type
Energy Class
Class B
61 kWh
42 W
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Power off timer, HDCP, Eco-Mode, 100% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, 90% NTSC (CIE 1976) colour gamut, borderless
Audio
Speakers
Output Power / Channel
2 Watt
VGA (HD-15) , 2 x HDMI , DisplayPort , Headphones , 4 x USB 3.0
Mechanical
Tilt Angle
-5/+25
Swivel Angle
330
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
TUV GS, GOST, RoHS
Security Slot Type
Kensington security slot
AC 100/240 V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
