The Q2790PQU is equipped with a QHD (2560 x 1440 pixels) IPS panel, delivering excellent color accuracy and a wide color gamut. Its ergonomic base in titanium finish complements the elegant 3-sided frameless design.
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
Integrated Speakers
Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers. -
Height adjustable stand
We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing. -
IPS Panel
No matter if you are viewing photos, videos, a magazine layout in InDesign or playing your favourite game – we want your content to look excellent from whatever angle you are seeing it. That is why this display comes with an advanced IPS panel, which produces brilliant colours and offers wide viewing angles. This way, images always look excellent and accurate, regardless from which angle you – or your friends and co-workers sitting or standing next to you – are looking at the screen. -
QHD Resolution
With 2560 x 1440 resolution, Quad HD (QHD) offers superior picture quality and sharp imagery that reveals the finest details. The widescreen 16:9 aspect ratio provides plenty of space to spread out and work, plus allows you to enjoy games or movies in their original size. -
Frameless Design
3-Sides frameless design of the monitor lets the user focus on the vivid display, and onlookers will enjoy the sleek and modern look from every angle. -
Wide Colour Gamut
When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
- AOC Q2790PQU/BT - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 61 kWh
- Power Consumption (On mode)
- 42 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB, 90% NTSC (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, GOST, RoHS
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 61 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Power off timer, HDCP, Eco-Mode, Low Blue Light Mode, Flicker Free technology, borderless
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- VGA (HD-15) , 2 x HDMI , DisplayPort , Headphones , 4 x USB 3.0
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 330
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- Cables Included
- 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 42 W
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
