AOC Q2778VQE 27" 2560×1440 1ms DVI-D HDMI DP LED Monitor
Quicklinx: B8NRWS00 Mfr#: Q2778VQE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£172.70 ex VAT
£207.24 inc VAT
Experience a new level of sharpness with this large 68.5 cm (27") monitor. The Q2778VQE utilizes a state-of-the-art TN panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from flexibility tilt and swivel function. The Q2778VQE comes in a glossy black design and features eco-friendly LED-backlights. Let the Q2778VQE impress you today!
AOC Pro-line Q2778VQE - LED monitor - 27"
LED-backlit LCD monitor - 27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
Glossy black
64.03 cm x 29.91 cm x 47.07 cm
4.72 kg
Environmental Standards
ENERGY STAR Qualified
FCC, RoHS, ISO 9241-307, WEEE, REACH, TUV Bauart, EuP, EAC
3-year warranty
Display Type
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, gamma correction, input select, graphic / text mode, phase, clock, luminance
Power off timer, HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, Break Reminder, HDR10 compatible
Glossy black
64.03 cm x 29.91 cm x 47.07 cm - with stand
4.72 kg
DVI-D , HDMI , VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-4/+21
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.2 m , 1 x DVI cable - 1.5 m
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Shipping Width
72.9 cm
Shipping Depth
21.5 cm
Shipping Height
55.5 cm
Shipping Weight
6.77 kg
ENERGY STAR Certified
Limited warranty - 3 years
AOC Q2778VQE 27 Bundle deal on AOC Q2778VQE 27" 2560×1440 1ms DVI-D HDMI DP LED Monitor
£271.87
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
