Product
AOC Q2778VQE 27" 2560×1440 1ms DVI-D HDMI DP LED Monitor
Quicklinx: B8NRWS00 Mfr#: Q2778VQE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£181.33 ex VAT
£217.59 inc VAT
Experience a new level of sharpness with this large 68.5 cm (27") monitor. The Q2778VQE utilizes a state-of-the-art TN panel with the stunning WQHD resolution of 2560 x 1440 pixels. With its D-Sub, DVI-D, HDMI and DisplayPort connectors, this energy-efficient display offers you a multitude of applications, delivering exceptionally crisp and vivid images for even the highest demands. Benefit further from flexibility tilt and swivel function. The Q2778VQE comes in a glossy black design and features eco-friendly LED-backlights. Let the Q2778VQE impress you today!
AOC Pro-line Q2778VQE - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
43 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Tilt
Glossy black
64.03 cm x 29.91 cm x 47.07 cm
4.72 kg
Environmental Standards
ENERGY STAR Qualified
FCC, RoHS, ISO 9241-307, WEEE, REACH, TUV Bauart, EuP, TCO Displays 6.0, EAC
3 years warranty
Display Type
Energy Class
Class C
64 kWh
43 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, gamma correction, input select, graphic / text mode, phase, clock, luminance
Power off timer, HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, Break Reminder
Glossy black
64.03 cm x 29.91 cm x 47.07 cm - with stand
4.72 kg
DVI-D , HDMI , VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-4/+21
Flat Panel Mount Interface
100 x 100 mm, Yes
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x power cable
29.01 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
AOC Q2778VQE 27 Bundle deal on AOC Q2778VQE 27" 2560×1440 1ms DVI-D HDMI DP LED Monitor
Including:
Microsoft Office 365 Business Premium Retail 1 Year Microsoft Office 365 Business Premium Retail 1 Year worth £99.99 | in stock
£281.32
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
