AOC Q2577Pwq 25" 2560x1440 5ms AH-IPS VGA DVI HDMI DP Monitor
Quicklinx: BVWGWS00 Mfr#: Q2577PWQ
Diagonal Size: 25in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£221.06 ex VAT
£265.27 inc VAT
The quad HD panel ensures that users can enjoy a full view of a website at a single glance without image distortion. IPS technology is one of the highest performing panel technologies currently available for displays. This way, AOC makes sure users will greatly benefit from high accuracy in color, contrast and wide viewing angles. The AOC Q2577PWQ comes with DisplayPort, HDMI, DVI and VGA. Also comes with a feature that ensures a zero-flickering viewing experience.
AOC Pro-line Q2577PWQ - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Stereo speakers
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Pixel Pitch
0.072 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, MHL, DVI, DisplayPort, VGA
Display Position Adjustments
Swivel, tilt
Black/silver
57.04 cm x 19.91 cm x 47.48 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
TUV Bauart, EAC
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
25"
Viewable Size
25"
Built-in Devices
Stereo speakers
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.072 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 99 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Built-in speakers
Black/silver
57.04 cm x 19.91 cm x 47.48 cm - with stand
6.5 kg
DVI , MHL / HDMI , VGA , DisplayPort
Mechanical
Swivel, tilt
Tilt Angle
-5/+23
Height Adjustment
130 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x power cable
TUV Bauart, EAC
55 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
Limited warranty - 3 years
AOC Q2577Pwq 25 Bundle deal on AOC Q2577Pwq 25" 2560x1440 5ms AH-IPS VGA DVI HDMI DP Monitor
£320.23
BVWG C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BVWG C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.43
BVWG C2G 5m Select High Speed HDMI with Ethernet In Stock £21.48
BVWG C2G 10m Select High Speed HDMI with Ethernet In Stock £41.23
BVWG C2G 15m Select High Speed HDMI with Ethernet In Stock £55.83
BVWG C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 25in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 150 - 300
