Your basket is empty
AOC Professional m2460Phu 24" 1920x1080 5ms VGA DVI-D HDMI LED Monitor
Quicklinx: 8H0SWS00 Mfr#: M2460PHU
This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
AOC Professional m2460Phu - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
USB Hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
56.54 cm x 24.458 cm x 39.36 cm
6.54 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, GOST, FCC, RoHS, ISO 9241-307, TCO '05, EuP
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB Hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+, i-Care
56.54 cm x 24.458 cm x 39.36 cm - with stand
6.54 kg
Audio
Speakers - integrated
USB upstream , DVI-D (HDCP) , VGA (HD-15) , HDMI , Headphones , 4 x USB downstream
Mechanical
Tilt Angle
-5/+15
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
Power Supply
Internal
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
ENERGY STAR Certified
