Product
Brand
AOC Professional I2770PQ 27" 1920x1080 6ms VGA DVI DisplayPort LED Monitor
Quicklinx: B3LNWS00 Mfr#: i2770Pq/bk
Enjoy brilliantly colored, vivid images on this large 68.6 cm (27?) widescreen monitor. Boasting a high-grade PLS panel with Full HD resolution, the i2770Pq/BK delivers exceptionally wide viewing angles for multimedia and office applications. With its D-Sub, DVI-D, HDMI connectors as well as speakers integrated into the bezel, this energy-efficient display offers you a multitude of options. Benefit from full ergonomic flexibility with 130 mm height adjustment, tilt, swivel and pivot function. The i2770Pq/BK comes in a classy black texturized design and features eco-friendly LED-backlights. Let this stylish monitor impress you today!
AOC Professional I2770PQ/BK - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
36.5 kWh
Power Consumption (On mode)
25 W
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
64.24 cm x 24.4 cm x 55.6 cm
8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, RoHS, ISO 9241-307, EuP, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class A
36.5 kWh
25 W
Diagonal Size
27"
Viewable Size
27"
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, Eco-Mode, i-Menu, e-Saver technology, Screen+
64.24 cm x 24.4 cm x 55.6 cm - with stand
8 kg
Audio
Speakers
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort , HDMI , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+25
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable
Power Supply
Internal
29.1 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
ENERGY STAR Certified
Limited warranty - 3 years
B3LN C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B3LN C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.98
B3LN C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
B3LN C2G 10m Select High Speed HDMI with Ethernet In Stock £31.89
B3LN C2G 15m Select High Speed HDMI with Ethernet In Stock £43.19
B3LN C2G Pro HDMI to VGA Converter In Stock £49.01
