AOC Pro-line U3277PWQU 31.5" 3840x2160 4ms HDMI DVI-D VGA DisplayPort 4K LCD Monitor
Quicklinx: D6WPWS00 Mfr#: U3277Pwqu
The AOC U3277PWQU helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals the finest details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction (95% NTSC and 100% sRGB, 1 billion colors), wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI-D makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video. Whether you're editing photography, working with CAD/CAM, or designing a website, the height-adjustable ergonomic stand tilts, swivels and pivots for hours of comfortable viewing.
  • Wide Colour Gamut
    When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette.
  • 4K Resolution
    Ultra high definition 3840 x 2160 resolution (4K UHD) yields a superior pixel density of 138 PPI (pixels per inch) on the large 32-inch screen, for outstandingly detailed images. The 10-bit Deep Color RGB display panel ensures substantially more natural transitions between hues for exceptional realism.
  • USB 3.0 input for all your devices
    USB 3.0 gives you more bandwidth and SuperSpeed data transfer – ten times faster than USB 2.0. With fast charge functionality, these hubs also quickly power your phones and tablets. USB 3.0 is ideal for connecting all your devices and peripherals to your display, and it's backwards compatible with USB 2.0.
  • Height adjustable stand
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of working comfort.
AOC Pro-line U3277PWQU - LCD monitor - 4K - 31.5"
LCD monitor - 31.5"
Energy Class
Class G
Energy Consumption per Year
74 kWh
Power Consumption (On mode)
39.9 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Height, pivot (rotation)
Voltage
AC 100/240 V (50/60 Hz)
Black, silver
74.2 cm x 17.1 cm x 65.9 cm
11.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV Bauart, EAC
3-year warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class G
74 kWh
Diagonal Size
31.5"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
HDCP, i-Menu, e-Saver technology, Screen+
Black, silver
74.2 cm x 17.1 cm x 65.9 cm - with stand
11.5 kg
Audio
Speakers
Output Power / Channel
6 Watt
Mechanical
Tilt Angle
-5/+24
Swivel Angle
165
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
Security Slot Type
Kensington security slot
Input Voltage
39.9 W
39.9 kWh/1000h
Power Consumption (Typical)
60 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
