AOC Pro-line U3277PWQU 31.5" 3840x2160 4ms HDMI DVI-D VGA DisplayPort 4K LCD Monitor
Quicklinx: D6WPWS00 Mfr#: U3277Pwqu
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
£346.10 ex VAT
£415.32 inc VAT
The AOC U3277PWQU helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals the finest details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction (95% NTSC and 100% sRGB, 1 billion colors), wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI-D makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video. Whether you're editing photography, working with CAD/CAM, or designing a website, the height-adjustable ergonomic stand tilts, swivels and pivots for hours of comfortable viewing.
AOC Pro-line U3277PWQU - LCD monitor - 4K - 31.5"
LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
74 kWh
Power Consumption (On mode)
51 W
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Height, pivot (rotation)
Black, silver
74.2 cm x 17.1 cm x 65.9 cm
11.5 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, TUV Bauart, EAC
3-year warranty
Display Type
LCD monitor / TFT active matrix
Energy Class
Class B
74 kWh
51 W
Diagonal Size
31.5"
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
HDCP, i-Menu, e-Saver technology, Screen+
Black, silver
74.2 cm x 17.1 cm x 65.9 cm - with stand
11.5 kg
Audio
Speakers
Output Power / Channel
6 Watt
Mechanical
Tilt Angle
-5/+24
Swivel Angle
165
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
Security Slot Type
Kensington security slot
AC 100/240 V (50/60 Hz)
60 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
AOC Pro-line U3277PWQU 31.5 Bundle deal on AOC Pro-line U3277PWQU 31.5" 3840x2160 4ms HDMI DVI-D VGA DisplayPort 4K LCD Monitor
£445.27
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Interfaces: VGA (HD-15)
Brand: AOC
Price Range Ex VAT: 300 - 500
