Product
AOC Pro-line U3277PQU 32" 3840x2160 4K IPS HDMI VGA DVI Monitor
Quicklinx: BVWHWS00 Mfr#: U3277PQU
The AOC U3277PQU helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals the finest details on a large 32-inch 16:9 screen that is ideal for multitasking. Featuring advanced IPS panel technology, you'll enjoy accurate color reproduction (100% sRGB, 1 billion colors), wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI-D makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video. Whether you're editing photography, working with CAD/CAM, or designing a new website, the height-adjustable ergonomic stand tilts, swivels and pivots for hours of comfortable viewing.
  • Adjustable height
    Raise or lower the screen to suit each individual's height and seating preferences. The easy-to-adjust stand ensures hours of viewing or working comfort.
  • Flicker Free
    AOC Flicker Free technology's hybrid solution regulates brightness without flickering ensuring comfortable viewing.
  • 4K UHD resolution
    4K UHD brings you the latest advances in viewing technology. With 3820 x 2160 resolution, it offers four times the pixels of Full HD in 16:9 format. These displays are designed for demanding professionals and home users that require the finest level of detail. From CAD and graphic design programs to scientific image and data analysis, these screens deliver superior accuracy and ultra-fast response times.
  • DisplayPort
    DisplayPort offers ultra-fast digital audio and video transmission without quality loss or input lag. Quickly and easily connect a range of devices to your screen, including your computer, laptop, media player, game console and more. It's perfect for professionals as well as the most demanding home users.
AOC Pro-line U3277PQU - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
88 kWh
Power Consumption (On mode)
60 W
Speaker, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments
Black, silver
74.188 cm x 17.12 cm x 65.9 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TCO '06, TUV Bauart, EAC
3 years warranty
Display Type
Energy Class
Class C
88 kWh
60 W
Diagonal Size
32"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
1 billion colours
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, i-Menu, e-Saver technology, Mobile High-Definition Link (MHL), Flicker Free technology, Zero power switch
Black, silver
74.188 cm x 17.12 cm x 65.9 cm - with stand
VGA (HD-15) , MHL / HDMI , DVI-D , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
Flat Panel Mount Interface
Stand
1 x power cable , 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
Security Slot Type
Kensington security slot
AC 100/240 V (50/60 Hz)
79 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
ENERGY STAR Certified
Limited warranty - 3 years
BVWH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BVWH C2G 5m Select High Speed HDMI with Ethernet In Stock £20.88
BVWH C2G 10m Select High Speed HDMI with Ethernet In Stock £40.08
BVWH C2G 15m Select High Speed HDMI with Ethernet In Stock £54.29
BVWH C2G Pro HDMI to VGA Converter In Stock £50.07
BVWH C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
