AOC Pro-line U3277FWQ 31.5" 3840x2160 4ms HDMI DVI DisplayPort VGA LED Monitor
Quicklinx: D6WNWS00 Mfr#: U3277Fwq
The AOC U3277FWQ helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals fine details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction, wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video.
AOC Pro-line U3277FWQ - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, MHL, DVI, DisplayPort, VGA
Display Position Adjustments
Tilt
Black/silver
74.188 cm x 17.82 cm x 51.69 cm
8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TCO '06, DICOM Part 14, REACH, TUV Bauart, EuP, EAC
3-year warranty
Display Type
Diagonal Size
31.5"
Viewable Size
31.5"
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
HDCP, MultiView, i-Menu, e-Saver technology, Screen+, 95% NTSC colour gamut, Flicker Free technology, BFR/PVC-free
Black/silver
74.188 cm x 17.82 cm x 51.69 cm - with stand
8 kg
Audio
Speakers
Output Power / Channel
3 Watt
DVI , VGA , MHL / HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, HDCP Compliant
1 x DisplayPort cable , 1 x power cable
Security Slot Type
Kensington security slot
AC 100/240 V (50/60 Hz)
50 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
ENERGY STAR Certified
Limited warranty - 3 years
