The AOC U3277FWQ helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals fine details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction, wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video.
4K Resolution
A 4k/UHD 3840 x 2160 resolution panel with a pixel density of 163 Pixels Per Inch offers 300% more screen space! With 4 times the detail of a normal HD monitor, 4k gamers are thrown into a world of crisp detail and razor sharp imagery that immerses like never before! -
Wide Colour Gamut
When you are enjoying photos, videos or games, we want your screen content to look as lifelike as possible. That is why this display comes with Wide Colour Gamut technology, which means that it is able to display a lot more colours than conventional monitors. This is achieved through a special hardware solution, not through mere software adjustments. The result: true-to-life images with fine details that become visible thanks to the broader colour palette. -
Flicker Free
AOC Flicker-Free Technology utilises a DC (Direct Current) backlight panel, reducing flickering light levels. With eye strain and fatigue absolutely minimised, feel free to enjoy those long, intense gaming sessions in comfort! -
Display Port
The most recent display interface standard from VESA, DisplayPort can also transfer audio, USB and other forms of data. DisplayPort version 1.2-1.2a support up to 165 Hz@1440p, 75 Hz@2160p, version 1.3 supports up to 240Hz@1440p, 120 Hz@2160p and the version 1.4 supports HDR10 specifications.
- AOC Pro-line U3277FWQ - LED monitor - 4K - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Energy Consumption per Year
- 74 kWh
- Power Consumption (On mode)
- 39.9 W
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1845 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 80000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 95% NTSC
- Input Connectors
- HDMI, MHL, DVI, DisplayPort, VGA
- Tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Black/silver
- 74.188 cm x 17.82 cm x 51.69 cm
- 8 kg
- Environmental Standards
- ENERGY STAR Qualified
- GOST, TUV Bauart, ISPO
- 3-year warranty
- Display Type
- Energy Class
- Class G
- 74 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1845 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 95% NTSC
- Response Time
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 160 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
- Flicker Free technology, slim bezel design
- Black/silver
- 74.188 cm x 17.82 cm x 51.69 cm - with stand
- 8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- DVI , VGA , MHL / HDMI , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m
- MTBF
- 50,000 hour(s)
- Input Voltage
- 39.9 W
- Power Consumption SDR (On mode)
- 39.9 kWh/1000h
- Power Consumption (Typical)
- 50 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- Shipping Width
- 62.7 cm
- Shipping Depth
- 21.4 cm
- Shipping Height
- 84.8 cm
- Shipping Weight
- 12.3 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
